I want to have this sharp thread face buried into the tube surface. For that I made spiral to go inwardly. But sweep takes unspecified outside path. How to fix it?
Maha,, Your path for this is a spiral.. I'm pretty sure you want to use a helix and continue with the same pitch as your thread.. Am I correct?
Also your part is in mm and the thread is 5/8-18.. (UNF?) I made your spiral a helix and made the pitch .05555 (1/18).. The pitch from thread to thread (added) remains the same.
I added a split line to measure.
Spiral?
How would that be manufactured?
How would mating part interface with a spiral feature?
