Hi everyone,
I'm see multiple issues with using the the design library feature to drag and drop a feature into a solid model. The placement and dimensions come in correctly, but the sketch origin does not end up in the origin of the part.
Is there a way to have the sketch origin match the origin of the model?
-The sketch used to create the feature library is dimensions so the center of the square is at the origin in reference to the two edges. (yet the sketch origin is not relevant to it?)
-The origin of the 3D model is shown in the construction lines.
I'm asking because sometimes I need to add additional shapes, and generally use the origin as a reference.
Jesse
Save the sketch as block, set Insertion Point.Save block to your local Design Library .
This block can be inserted to the sketch in any model and easily positioned using Insertion Point to match the Origin.
