I'm not sure if this is possible (and not really sure how to ask/word this), but I have a sheet referencing a subassembly view to populate the title block, and I want to change this so the title blocks takes info from the assembly view on the same sheet... Is there some setting to change the "main" view on a sheet?
Nvm, I found it...
RMB on SheetX in Feature Tree > Properties... > Use custom property values from model shown in: > [select drawing view to populate title block from, i.e. "main" view]
