17 Replies Latest reply on Dec 8, 2017 1:50 PM by Kevin Chandler
    When using quotes (double prime) for inch math operation does not work
    Andrew Terry
      While doing a math operation on a dimension within a model, using quotes (double prime, " ) the operation failed. It either stayed unchanged or you cannot click ok. However, when using "in" for inch the operation works. I am able to do this operation using quotes on other stations. I haven't found any solutions or seen anywhere on the web where someone was had the same issue.
      Example 1: 408mm + 2" (does not work)
      Example 2: 408mm + 2in (works)
      Solidworks 2016 SP 5
      Windows 10
