I copied the Toolbox ANSI Inch standard to make a customized standard, and I get different results from the <hw-descrp> field. Can that table be edited somewhere? I edited the calloutformat.txt file at the same time, and my changes are showing up. However, the result from the <hw-descrp> field is different between the two standards even though it was a direct copy.
Example (Top callout is from the copy, Lower callout is from ANSI Inch):
Both holes were inserted the same way, and both have the same text fields, i.e.
<MOD-DIAM> <hw-diam> <HOLE-DEPTH> <hw-depth>
<hw-descrp>
Best I can tell is you created one hole with nominal selected and the other with press selected?
