hello everyone,
This seems pretty basic, but i cant get it.. I am creating a surface loft on two intersecting profiles. I cant figure out why the loft on the one end will not match up with the sketch profile. See scn shot. It is not an image quality issue.
Hey Ryan, is there any chance you can upload the part? Lofts can be tricky you may need more guide curves, you could also try boundary surfaces and then knit surfaces to a solid. Also in my experience having the same amount of line segments on each sketch helps greatly. If you have a spline make sure there is the same amount of points on each spline.
