Hi
I am trying to fill the holes using the filled surface command one by one
is there a better way to fill all the holes at one and supress the lines
Regards
srini
Hi
Regards
srini
You can still be able to create 3D points after suppressing the feature. Not sure if I'm missing something here?
Chris
I am using the Following Command
Insert-> Reference Geometry-> Points
Step1-And selecting the Each hole one after another.
Step2-Delete the Holes as said in this post by using untrim or right click delete option
Step3 covert the point created(step2) to hard point so that a reference node will be created during FE modelling
Regards
srini
you could use the untrim feature
