VDVasili Delizisis03/12/2017
Hi
I am trying to make a user form where buttons and textbox are created on run time.
When the macro runs It searches for parts in the assembly and checks for a specific custom property and If true it creates a textbox with the filename and a toggle button next to It. The problem I am having Is that I need to add code for the toggle button on run time as well but I am stuck.
I have used the code below to insert lines of code but get an error: run-time 438 Object doesn`t support this property or method,
stops at the line ( With Myuserform.CodeModule)
I also have the reference Microsoft Visual Basic for Applications Extensibility 5,3 active
There Is a lot of examples on google ( mostly for excel ) but I cant get them to work with Solidworks .
Anyone knows what I am doing wrong here or guide me In the right way?
Dim MyUserform As Object
Dim X As Integer, MaxWidth As Long
Set MyUserform = UserForm1
    With MyUserform.CodeModule
        X = .CountOfLines
        .InsertLines X + 1, "Sub togglebutton1_Click()"
        .InsertLines X + 2, " msgbox "Hello World"
        .InsertLines X + 3, "End Sub"
    End With
