can we revolve open sketch & construction lines? like in UG(NX)
Working with contour aslo not works or will take too much time, but in UG there is selection manager tool by which works faster, do we have such option????
Ashok
Did you try the contour select? you can select contours or regions and it will give you insight into the problems with the sketch, by seeing what gets highlighted.
I'm guessing your best bet is to use this imported sketch as the basis of new simpler sketches that you use to create your features.
In a new sketch Right click and choose Select Chain, then convert entities. Just a suggestion?
Ashok Kumar wrote:
Plz just make this sketch & try, beacuse UG having this option.
In 15 yrs of using SolidWorks I have never made a sketch that "ugly" complex and without dimensions.
Is that usual practice in NX?
When I have to start from AutoCAD reference - I generally start from scratch unless it was I who created the AutoCAD geometry (and usually even if it was I who created the AutoCAD geometry).
Open sketch as thin feature. Construction lines no.
