Simulation with spring connector - to simulate locking mechanism between teeth.
Question asked by Samuel Murley on Nov 30, 2017
I am trying to find out the stresses on material on a simple locking mechanism that uses a spring to allow teeth to pass one another when enough force is applied.
I am using a disc spring that allows 0.2mm of deflection when 10N of force is applied.
I believe that the simulation is set up correctly as when I suppress the spring connector all the parts move and behave as I would expect and the simulation runs fine.
However, when I unsuppress the spring connector I am unable to run the simulation.
I receive the error -
'Exception code 0xc0000005 thrown at address 0x1413886d0 in: Star.exe file version 28,1,0,20.
Please press OK to terminate solution'
I wanted to use this simulation to find a good shape and material for the 'teeth'.
I have attached a folder with the Assembly and parts - and the simulation 'static with spring'. I have also added some screenshots showing how the part moves with the spring connector disabled.
If anyone can help or suggest anything it would be greatly appreciated!
Sam
