I'm working sheet metal with multibody as below picture,
Cause of body mirror theese parts' flat patterns are same, but cause of hole position bending directions are diffirent, that is i'm trying to explain 2 parts are different. But Solidworks 2017 SP0 is showing as same parts at cut list.
I'm sure that solidworks 2008 to 2016 was providing us to perceiving whether parts are symetric or not
Shortly, if i draw this parts with Solidworks 2016 there wont be any problem. I was be seeing different 3 item at cut list
is it software wrong or is there any option to correct it?
Thank you for your urgent answer....
I am on SP4.1 and if all I do is press Ctrl+q, the cut list separates into 3 list items. So maybe there was an issue with SP0
