Is there such thing as panoramic section? And if yes, how can i draw it? Because i’ve got a plan with cruved walls and I don’t know how to take a section from it.
I want to draw a curved section but i dont know how its gonna look like, like should it look curved ? And can the section line be a curve not a straight line?
A curve cannot be used for a section line cut, but you could create a configuration in the 3D assy model & make a cut-extrude in that. The result could then be used as a view in a 2D drawing.
You could make a derived configuration in the assembly and then use an assembly cut
