I'd like to show the same specific component a number of times on different sheets. Its a servo controller without about 75 pins.
For example,
used once in a detailed wiring diagram showing a subset of the pins (mostly power)
used again in a another wiring diagram showing the remainder of the pins (mostly control)
used again in a detailed ladder schematic of same circuit
Finally used again in a block diagram, but for this I do understand how to create a a "single line symbol".
Can this be done without creating multiple components in the BOM?
I though maybe using "cross references" as is done with relay coils and contacts.... but this doesn't seem right for a complex component like this?
