Good morning All,
I have a strange issue with the dual dimensions not showing properly on my drawing, but only on sheet 3. Sheets 1 & 2 are fine. Note that I copied my sheet 1 to sheet 2, then sheet 2 to sheet 3 to maintain my title blocks, etc but this has never been a problem in the past. I've highlighted the dual dimensions on sheets 2 & 3. You'll notice they show correct on sheet 2 per the units settings in options, but I've tried all kinds of stuff to get them to show in feet-inches are sheet 3 but the same dimension format keeps showing. Tried a forced rebuild, restarting SW, change to another units set then change back, etc to no avail. Any idea? Thanks in advance.
Sheet 2 (shows properly with dual dimension in feet-inches in brackets):
Sheet 3: (shows incorrectly with same unit style in both):
My settings: (same for the individual part files and assembly files as well):
As suspected, your dimension was not falling in the 1/16 fraction and hence SOLIDWORKS was unable to display it. Just turn the option to round to nearest fraction (under units) and you should be good
