1 Reply Latest reply on Nov 28, 2017 2:37 AM by Manikandan Babu
    How to set Dual Dimension for manually drawn dimensions in drawing using solid works API c#
    Girish Kumar
      I have following scenario,the below shown Sketch dimension to set as Dual dimension using the code
      boolstatus = partDoc.Extension.SetUserPreferenceToggle((int)swUserPreferenceToggle_e.swDetailingDualDimensions, (int)swUserPreferenceOption_e.swDetailingDimension, true);
      The above code works for Drawing view, but the below scenario is a sketch.
      I want to set all the manually drawn dimensions in drawing file to be also set to dual dimension using SolidWorks API c#
      Girish
        • Re: How to set Dual Dimension for manually drawn dimensions in drawing using solid works API c#
          Manikandan Babu
          Hi Girish
          Select the dimension and debug it.
          static void Main(string[] args)
                      SldWorks SwApp = (SldWorks)System.Runtime.InteropServices.Marshal.GetActiveObject("sldworks.Application");
                      ModelDoc2 SwModel = (ModelDoc2)SwApp.ActiveDoc;
                      DrawingDoc SwDraw = (DrawingDoc)SwModel;
                      //Select the dimension manually
                      SelectionMgr swSelMgr = (SelectionMgr)SwModel.SelectionManager;
                      DisplayDimension swDispDim = (DisplayDimension)swSelMgr.GetSelectedObject6(1, 0);
                      int longstatus = swDispDim.SetUnits2(false, (int)swLengthUnit_e.swMM, (int)swFractionDisplay_e.swDECIMAL, 0, false, (int)swUnitsDecimalRounding_e.swUnitsDecimalRounding_Truncate);
                      swDispDim.SetDual2(false, true);
                      SwModel.ForceRebuild3(true);
          Manikandan
