I am working on an assembly profile and when I try to get a cross section view, solidworks slowdown and would not responding for a long time. I have tried cross section each parts inside individually, but they works well then.
And the cross section works well if I just isolate several parts in the assembly.
Anyone have similar problems? And please let me known how do you solve it.
Thanks.
If the section view is cutting through any imported geometry parts,(such as step, parasolid or Iges) I have seen this behavior befor.
Usually I find it to be a part that just has outside surfaces with no bodies. Solidworks can't cut through it so it either gives you an error message or it crashes.
