I loaded several jobs in the Queue this last week and expected them to be completed. Upon checking this morning apparently they all failed. Is there a place I can view why they failed?
Are you running Windows 10 or Windows 7 Chris? One thing I do that helped reduce the same problem for me, but not stop it completely though, was to suspend Windows 10 updates.
At the tab to manage updates in Windows 10, under advanced, there is a spot where you can suspend updates for up to 20 days. Before I fire off the queue that I know is going to run for days, I suspend the updates so they won't do something to interfere with the PC's processing.
If I were running Windows 7, I would turn off auto updates during a time I would need to run the queue for days.
Like I said, doing that has helped but not completely eliminated that issue for me.
Solution Id:S-074366
Question:When using the Queue with SOLIDWORKS® Visualize, why do I see the following error? ‘Unable to connect to local queue. Make sure the service is running and try again.’
This issue can occur if a system failure interrupts the SOLIDWORKS® Visualize Queue. Any subsequent renders will try to restore previous sessions, which could have been corrupted by the crash.
Answer:
To clear any previous sessions and restart the Queue, follow these steps:
1. Stop the Queue service.
a. Go to 'Control Panel' > 'Administrative Tools' > 'View local services'.
b. Right-click on the ‘SWVisualize[version].QueueServer’ service > ‘Stop’.
2. Delete the following files:
• %PROGRAMDATA%\SOLIDWORKS\SOLIDWORKS Visualize [version]\Queue\admin\processorscheduler.state
• %PROGRAMDATA%\SOLIDWORKS\SOLIDWORKS Visualize [version]\Queue\admin\queue.state
3. Restart the Queue service.
b. Right-click on the ‘SWVisualize[version].QueueServer’ service > ‘Start’.
Ok had an idea. I think the render Queue is timing out because of the large file. I think if I change the render Queue timeout to a much larger number I should be fine. How do I stop the queue in order to do that? The queue is not open, I have tried several times to stop and close it but I keep getting an error message. Thoughts?
I have the same problem in 2018 version.
Queue render some jobs and then returned a "Job Failed" error for rest of jobs.
I attached the log files.
This seems to happen over the weekends. Any suggestions or thoughts?
