Hi all,
I am new in solidworks, before i use Autodesk Inventor.
to make hole in hole wizards,
do we can make hole position automatic using point that defined from sketch and known for quantity of
hole that we will make?
I need it for solve hole position for nut that in large amount of hole.
Regards,
Yudika
You are going to have to make a constrained sketch that contains all the points you require,
and select each location that you require each hole type to be placed.
You could use the pattern feature if the holes are geometrically arranged.
