Hi All,
Iam unable to fit the SW screen in desktop.While using the F11 key only i can see the bottom where dimension information tab visible but the top is not visible at that time.
Hi All,
Don't use the F11 function key, just double-click the top grey bar where the part/assy name resides, or use the Maximize/Restore icon at the top RH corner.
Arun Kizahke Kuruminiyil wrote:
Hi Kevin,
I find the solution.Actaully the status tool bar was not not clicked .
Hi Arun,
This topic documents the fact that the visibility mode of different UI elements, including the status bar, are tracked seperately for regular mode vs full screen mode. So this explains the behavior you are seeing.
2018 SOLIDWORKS Help - Full Screen Mode
Jim
Hi Kevin,
