I'm getting the "This part has features defined in the context of another assembly <old version.sldasm>..."
I've done some searching on the forum and see that checking tools> options> system options> external references> allow multiple contexts will solve this but it is usually accompanied with a cautionary warning to only do that if you know what you're doing. I have no shame in admitting I have no idea what that is doing and so am wary of checking it.
My scenario is I have an electronics enclosure; outline of PCB came from offset of enclosure; mated PCB to enclosure; mated connectors to PCB; then using connectors and Intersection Curve to place the cutouts through the enclosure for the connectors.
I will not be going back to "old version.sldasm" so am fine to break the association with the old assembly, but would like them to be associated with the new assembly. I can edit the new enclosure, and the error only pops up once I click the connector when trying Intersection Curve. So are the links I'm looking to break on the connector? The old enclosure? Or the new enclosure?
