Macro for Deleting Item off Current Drawing Sheet
Question asked by Taylor Duran on Nov 21, 2017
I am trying to create a macro that will delete a note off of a current drawing sheet format.
The note is standard on the template but is only needed on certain drawings.
When I recorded the macro it worked fine but would only delete the note from the single sheet in the drawing and wouldn't work on any other.
I think I am am close but am having trouble specifying the current sheet. This is the code I have so far. Any help & suggestions would be greatly appreciated
Dim swApp As Object
Dim Part As Object
Dim swConfig As SldWorks.Configuration
Dim swDrawingDoc As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim nDocType As Long
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
Set swDrawingDoc = swModel
Set swSheet = swDrawingDoc.GetCurrentSheet
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("& swSheet.GetName() &", "SHEET", 8.88251268656716E-02, 0.249583432835821, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("DetailItem159@ & swSheet.GetSheetFormatName() & ", "NOTE", 0.390947932206707, 0.230293898698196, 0, False, 0, Nothing, 0)
Part.EditDelete
boolstatus = Part.Extension.SelectByID2(" & swSheet.GetSheetFormatName() & ", "SHEET", 0.284276326189945, 0.223110625565754, 0, False, 0, Nothing, 0)
Part.EditSheet
Part.EditSketch
' Zoom To Fit
Part.ViewZoomtofit2
Thanks in advance!
-Taylor
