Why is the description in my BOM table for a sub-assy the configuration name?
Also, how can I change to the logical 'description' from the properties as default, like it should be?
If I change the configuration name, the drawing then says something has changed and uses the correct description. However, when I re-open the drawing, all has changed back.. again.
Hi Martin
If you switch to the config tab and Right Click and select properties you get these options. What are yours showing?
