I am having some problems with designing a parametric design of a conveyor. I made a simple part with a width, lengt and an angle. And I want to make different configurations for the width and the angle but not the length. I want to be able to change the length manually. And I know that it's possible to change this length in the assembly. But sometimes I need this part more than once with different lengths.
Is there a way to achieve this?
Look into Configuration publisher in case you want to create configurations in the same model OR DriveWorksXpress (free add-in for automation) in case you want separate file every time you've different values.
