Hi all.
At work I use Draftsight pro, so far with few problems, However at home I use the free version.
Yesterday as I was at home using the free one I typed PU, which is the AutoCAD equivalent of 'Clean' (Purge), I still use quite a lot of Acad commands as I was brought up mainly with it before moving to DS. I was met by help box stating 'unrecognised command' Anyone else had this problem, as I've never had it before?
My work pro version still accepts it.
Thanks.
Andy.
Works fine for me. What DS version you're using at home. Can you type -Clean and see if that works?
