Format Changing in Solidworks API
Question asked by John Boire on Nov 17, 2017
Latest reply on Nov 17, 2017 by John Boire
So, after doing a bit of research and wrote this macro to cycle through the sheets in a drawing and update their format:
Dim swModel As ModelDoc2
Dim swSheet As SldWorks.Sheet
Dim SheetName() As String
Dim SheetNum As Integer
Dim boolstatus As Boolean
Dim bRet As Boolean
Set swDraw = swApp.ActiveDoc
Set swModel = swApp.ActiveDoc
swDraw.ClearSelection2 True
SheetNum = swDraw.GetSheetCount
SheetName = swDraw.GetSheetNames
Debug.Print (SheetNum)
For i = 0 To SheetNum - 1
Debug.Print (SheetName(i))
bRet = swDraw.ActivateSheet(SheetName(i))
boolstatus = swDraw.SetupSheet4(SheetName(i), 12, 12, 1, 2, False, "Y:\Engineering\01_Engineering Technical Library\08_Ligistics\CAD Tools\SolidWorks\TEMPLATES\OPER SHEET -A-.SLDDRT", 0.2794, 0.2159, "Default")
'Comment out 'boolstatus = swDraw.SetupSheet4(SheetName(i), 12, 12, 1, 2, False, "Y:\Engineering\01_Engineering Technical Library\08_Ligistics\CAD Tools\SolidWorks\TEMPLATES\OPER SHEET -A-.SLDDRT", 0.2794, 0.2159, "Default", True) 'Comment out
Debug.Print (boolstatus)
'Comment out 'boolstatus = swDraw.SetupSheet5(SheetName(i), 12, 12, 1, 2, False, "y:\engineering\01_engineering technical library\08_ligistics\cad tools\solidworks\templates\oper sketch -a-.drwdrt", 0.2794, 0.2159, "Default", True) ' Comment out
swModel.ViewZoomtofit2
Next i
The cycle works and runs through the sheets, the path is correct (I double checked for capitalization) but for some reason the sheet format doesn't update. Is there anything I am missing?
