I have a very simple sheetmetal part, but I could not create mesh. I tried all the highlighted parameters but does not help. Please see the attached pictures and part file.
With "verification on rebuild" enabled I get errors on rebuild, just like Iain does.
With "verification on rebuild" disabled I do not get errors on rebuild, just like Marco's case.
I'm using SW 2017 SP 3
I notice that the existing study is set for a solid mesh. This part isn't really a good match for solid mesh, especially with the hems.
When I try to switch to a shell mesh ("treat as sheet metal") it tells me there are some issues. I think these issues are probably the same ones that cause the rebuild errors.
Marco... I have fixed your model to the point where I don't get any errors with VOR on. Basically did normal cuts and fixed up the flanges/hems to where they no longer interfered with one another. I don't have simulation so I used Xpress and was able to mesh this as a Solid Mesh. I know you have changed your model but you didn't mention whether you were able to mesh it. I'm curious.??
I have attached my "fixed up model". It would be interesting to see if it works in your simulation.
Hi Marco,
When I did a Ctrl+Q rebuild on your part I got quite a few issues. If you repair these it may enable you to mesh. If it still doesn't, please re-upload the fixed part.
