Can't find the instance of a sketch block definition on a drawing sheet.
Question asked by Gregory Ashmore on Nov 16, 2017
Latest reply on Nov 17, 2017 by Josh Brady
I have a SketchBlockDefinition in a drawing.
The drawing has just one sheet.
There is an instance of the sketch block definition in the sheet format.
I activated the sheet and retrieved the first view, which I believe is the sheet view.
I got the sketch for the view and called GetSketchBlockInstances.
The return was Nothing.
I expected to get a reference to the block instance that is in the sheet format.
In this drawing, which has only one instance of the sketch block definition, I could get the block definition from the document sketch manager, and retrieve the instance from the block definition.
But in the general case, there may be multiple sheets, each sheet having its own instance of the block definition in the sheet format.
I need to discover the location of each instance in its sheet so that I can insert an entity at an offset from that location.
I can get the sketch from the instance, but I don't see anyway of determining which sheet the sketch is associated with.
So I have no way of associating the instance with a sheet.
How can I get the instance of the sketch block definition in a sheet format?
Thanks.
Here is the code:
   Private Shared Sub DatamatrixInstanceLocationsGet()
      Dim nInstanceSeen As Boolean
      Dim iSheetCur As Integer
      Dim sSheetName As String
      Dim oMathPoint As MathPoint
      Dim oSketch As Sketch
      Dim oaSketchBlockInstances() As Object
      Dim oSketchBlockInstance As SketchBlockInstance
      Dim oView As SolidWorks.Interop.sldworks.View
      iSheetCur = 0
      While iSheetCur < iSheetCount
         sSheetName = oaSheetNames(iSheetCur)
         oDrawingModel.ActivateSheet(sSheetName)
         oView = oDrawingModel.GetFirstView
         oSketch = oView.GetSketch
         nInstanceSeen = False
         oaSketchBlockInstances = oSketch.GetSketchBlockInstances <<<<<<<<<<< returns Nothing
         If oaSketchBlockInstances IsNot Nothing Then
            For Each oSketchBlockInstance In oaSketchBlockInstances
               If oSketchBlockInstance.Definition.FileName = sDatamatrixBlockDefinitionFileName Then
                  oMathPoint = oSketchBlockInstance.InstancePosition
                  faDatamatrixBlockOriginX(iSheetCur) = oMathPoint.ArrayData(0)
                  faDatamatrixBlockOriginY(iSheetCur) = oMathPoint.ArrayData(1)
                  nInstanceSeen = True
            Next
         If Not nInstanceSeen Then
            Throw New Exception("Datamatrix sketch block not found on sheet " & (iSheetCur + 1).ToString)
         iSheetCur += 1
      End While
      oMathPoint = Nothing
      oSketch = Nothing
      oaSketchBlockInstances = Nothing
      oSketchBlockInstance = Nothing
      oView = Nothing
