After moving my PART files into a new directory called "Parts", and my DRAWING files into a directory called "Drawings", obviously the links will be broken when i open the DRAWING file. Instead of Replace, Is there another way to reconnect the PARTS to the DRAWING file? I am hoping there is a simple way to simply change the file path in a preference somewhere instead of "Replacing" all the components.
Thanks!
When you open the drawing, before opening it select the "references" button,
Now if you double click on the location you will be able to search for the new file path.
