I can export the flat pattern blank, but it won't work with the added bend lines?
thanks.
thanks.
Yes, I check everything i want in my .dxf. But the only way I can seem to export is if I have everything checked off.
I know I have been through this before but my memory is not so good. I do have a custom map file but did not use it for my export so I'm wondering if you have Line styles set to AutoCAD Standard Styles in your export options. That may be it,, just sort of grasping at straws at the moment. I know others will know the exact cause for the bendlines not showing in your DXF..
Edit:.. Wanted to add that I save directly to my cad/cam from SW,, so I'm not that familiar with the dxf method.
Jeff,,, I'm assuming you are exporting to DXF.. Is that correct? If so you have the Bend lines checked?
