New SW user here...
I have some planes and axes in a part that I want to hide, and some others that I want to show. And then, at some point, I'll want to switch, and hide the ones I could see and show the ones that were hidden.
These axes are almost coincident, but not quite, so to make sure I select the correct axis, I turn half of them off. There are several of these planes and axes that go together. I don't want to have to click each one individually to turn it off or on. I want to do just a couple of clicks.
I looked at display states, but I seems you can only have one display state on at a time. This means if I wanted both groups hidden, I'd have to create a third state. And of course while I was using any of them, everything else would appear in its default state.
Which reminds me, how do I turn off all planes and axes at once?
See the attached video:
Shows you all of it.
Basically, to hide individual things, use the slide out pane that I first click on.
To hide all of a type of thing at once, use view, or the little eyeglasses icon (or the eye for version later than 2015).
