Hi guys,
I'm evaluating the SolidWorks PCB Connector for data exchange between Altium and SolidWorks and I wonder why the whole geometry is being missed when pulling the PCB through the Connector. The board itself is being translated and shown properly, the components appear correctly in the feature tree, but you cannot see them. When opening a component you see an empty feature tree, no geometry.
We found out, that using standard (as provided after installation) file templates solves this problem. So, there has to be a problem with our templates.
We use SWX 2017 SP2 and are not willing to upgrade in the next two years. All of our templates were made from the 2017th original / standard templates, of course with a lot of customization afterwards.
So, does anyone know what the exact problem might be (file properties, drafting standard, unit system...)? Our VAR says that in SWX2018 this issue has been solved, which is unsatisfactory in our situation.
By the way: Why you cannot set the defaut template separately for the PCB Connector components as it is already possible with the CircuitWorks add-in?
Thanks a lot!
Piotr
Hello Karishma DCOSTA,
this was observed with SolidWorks 2017 SP2 and PCB Services from the 2017th version.
After installing PCB Services 2018 and updating to SolidWorks 2017 SP5 this problem disappeared. I think, that PCB Services 2018 did the job. Refering to what our VAR was suspecting it seems to be connected with user defined templates (renamed coordinate System).
After testing PCB Connector under SolidWorks2017 I have found so many bugs in importing and exporting PCB designs from / into PCB Connector, that I will wait until 2019 or 2020 Version to test it again (with the next SolidWorks / PDM upgrade in our Company).
