I am trying to change the 'snap to ground' to a different face. At this moment it automaticly snaps to the lowest face in the model, but I want it to snap to a different face. Is this possible?
I believe it just snaps the bottom part of the bounding box to the ground. You can view the bounding box by going into settings and turning on.
To change what side snaps to the ground. Go back to your viewport and click on your model. Then down below in the panel on the left select rotate.
Keep rotating until the side you want is facing down. Then click snap to ground.
