Hi everyone,
I have built an assembly with several movable parts. If I move a part, SW only moves what is necessary to fulfill the constraints. What I would like to happen is that when moving a part, everything that is attached to that part will stay grouped to the moving one, while the rest should stay fixed. I have looked at the "Temporary Fix/Group" option, which achieves a similar effect, but I would like it to happen every time I move something. Can this be done in SW?
I have attached a file to demonstrate what I mean: If the middle part is moved, the top one stays in place. What I need to happen is that the top part stays in place relative to the middle one.
[Edit]
Also, I want to be able to move the top part in such a way that the middle and bottom part stay fixed.
So:
- Move middle part -> Top part stays fixed to middle part
- Move top part -> Only top part moves, other two stay fixed
[/Edit]
[Edit 2]
I have attached a second assembly (to avoid any confusion: All the parts are virtual, so the assembly is self contained) to demonstrate my problem.
- Note how moving the black part (the one that is not fixed) does not move anything else
- Now move the single rod at the top. The middle black part seems to stick to it
Is there any way I can reverse this effect? (i.e. rod sticks to black part, but black part not to rod) The reverse effect is obviously achievable.
[/Edit 2]
Message was edited by: Lukas Lang (added clarification)
Message was edited by: Lukas Lang (added second example)
Lukas,
You have attached only the .sldasm file. You need to use File, Pack & Go to save the sldasm file and its associated sldprt files to a zip file, then attach that to your message.
Only then will the forum users be able to open your assembly.
John
