I want to make some of the fields in my title block editable, but I'm having trouble with one of the fields. I get the following message when I try to select it:
"This note cannot be included because it is linked to a parameter which is not editable"
This is how my title block looks like:
And these are the fields I would like to make editable:
The one field I can't select is the Client field, which I can't see why I shouldn't be able to select ?
Are you using the Custom Property Tab Builder to create the properties you want to link to at the part level?
If so, can you show us the CPTB screen shot?
Also, can you share a screen shot of the Custom Properties area of your part that is linked to this drawing?
