Boss extrude 3 looks fine, but when it's mirrored it's not up against the wall like it's supposed to be. Part of it is off the wall and part of it is embedded into the wall. What's wrong here?
Extrude3 isn't on the interior surface.
Since the helmet continues arcing inward above Extrude3, the coradial is inboard of the surface.
Create a perp plane to Plane8 and the central axis and in section you'll Extrude3 is proud of the inner surface.
Because of that is, I believe, why Mirror6 goes goof.
Cheers,
Kevin C.
I am with you Eric.....I am not sure I understood all that either. But I can't open the part, so I am running blond blind anyway.
Kevin Chandler , can you translate that to some sort of Solidworks Lingo? LOL Just picking on you, but seriously, I did not follow what you said.
Kevin Chandler, Whether Boss-Extrude3 is merged or not with the helmet shouldn't make a difference, because the Mirror6 feature used the Bodies option.
The location of the mirrored body is just wrong.
I don't know why that mirror isn't working. It appears to be a glitch or bug.
Workaround: Create an axis at the intersection of the front & right planes, and use a circular pattern.
It isn't a glitch or a bug. Every vertex on the mirrored body is correctly mirrored across the mirror plane. The mirror plane definition is incorrect. The mirror plane is defined as the midplane between the Front and Right planes, but the feature being mirrored isn't located symmetrically between the front and right planes. This view shows what's happening.
your part appears to be symmetrical. why not just cut the part in half and mirror/pattern the whole body that is modeled correctly. much easier approach with less room for error.
using insert>features>combine merge your bodies in to one and will often remove surface/knit lines as a result. even when it doesn't, the geometry is there to produce the tool which will in turn yield the helmet as a finished product. even if a surface appears split, but is identical/symmetrical the machining program is smart enough to treat is as one continuous region so it wouldn't show up from any method of production via additive or conventional machining.
Newell,
But in this case, wouldn't the helmet shell be injection molded? In that case, it would be best to combine the bodies, correct?
yes you are correct and that is what I was trying to offer as a solution. I simply put it that way because I wasn't sure if he had already combined the bodies or not since I didn't look at the file. I was just trying to say that split lines on a surface will not impact or translate to a finished product.
