2018 has a nifty new feature that allows you to rotate a part in a linear pattern, but it appears this is ONLY available in Assemblies. WHY!? I work with weldments regularly, and that would have been a life saver. I'm currently working on a staircase project that alternates directions. If I could completely model out the pieces of the first floor and easily rotate it 180 degrees and up to the next floor, and repeat 5 times, I'd be one happy camper. I understand that I could move it all into an assembly and pattern there, but I rely on the use of an accurate cut list and avoid assembly BOMs as much as I can. If there's another way to go about that, I'm all ears
There is available the circular pattern for part document. You can use a solid part instead operations. Is it not what you're looking for?
