hello everyone,
I have a problem exporting a BOM table in .txt file:
I have a "part number" column and in this column for a specific component I set in configuration manager a user specified name that is :
1005060."D1@Estrusione-Estrusione2@1005060.SLDPRT"
Where 1005060 is the part code, then I need a "." and a dimension that I want to see in BOM table.
In BOM table it works correctly, with a problem, it Leaves a blank space between the "." and the dimension:
1005060. 1658
That blank space is annoying for me because it cause me trouble importing the BOM in our management software, but the main trouble is that when I export the table as .xls file the result is 1005060. 1658, but exporting as .txt file the result is 1005060. "D1@Estrusione-Estrusione2@1005060.SLDPRT".
I could accept the blank space but our management software requires a txt file so I can't import it with this result.
Any idea about how can I get rid of it?
Thanks everyone
Andrea
