1-C58PCB
Tip of the day - Publish portrait format images
Discussion created by 1-C58PCB on Jan 24, 2009
When you have a model which has higher length vs. Breadth aspect ratio and you want to publish vector image, by default, Composer creates a preview window which splits graphics view horizontal. It leaves lot of white space around vector image. If you want to switch to portrait format, simply select "View -> Layout -> Two Vertical Views". You should now have the vertical preview window which occupies maximum space with vector image. See attached snapshot.
That surely saves you time from croping the image before using in your final document.
Hope this tip helps.
Enjoy!
Rakesh
