Hello, My second question on the forums and i hope to use the advantage of your experience,
i'm working on the CAMARO tutorial ( the one from 2010 ) to use it for a CFD analysis of drag and pressure loads at high speeds,
i'm at around 85% done with the model where i tried to run the simulation and after nearly 4 hours i realized that simulations don't work on surfaces, so i tried to thicken the model after applying knit surface, and started getting all sorts of messages that it won't work,
any advice would be greatly appreciated,
Hi Majd,
Do you have the model?
