DTDiogo Teixeira11/11/2017
The purpose is to mate two components using one selected face from each of them. In other words, I intend to use a procedure that gets into the selected component and goes through all faces until it finds the one by name, selecting it. Therefore the procedure is called two times, after selecting each of the components individually, so both are traversed in its faces, and then having both faces selected.
The issue starts after selecting the first face when I try to get into the second component without succeeding in adding the following face to the selection list.
I would like to know how to have these two faces selected so I can proceed with the mate.
This is the code:
Sub mate_pino_porca()
    Dim swApp As Object
    Dim AssyDoc As Object
    Dim longstatus As Long
    Dim MyMate As Object
    Dim CompName As String
    Dim FaceName As String
    Dim CCompName As String
    Dim FFaceName As String
    Dim boolstatus As Boolean
    ' Get active Assembly document
    Set AssyDoc = swApp.ActiveDoc()
    CompName = "porca quadrada-1@Assem_pino_porca"
    FaceName = "concentrico_porca"
    CCompName = CompName
    FFaceName = FaceName
    boolstatus = AssyDoc.Extension.SelectByID2(CompName, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
    SelectComponentFaceByName CCompName, FFaceName
    CompName = "pino-1@Assem_pino_porca"
    FaceName = "concentrico_pino"
    boolstatus = AssyDoc.Extension.SelectByID2(CompName, "COMPONENT", 0, 0, 0, True, 0, Nothing, 0) '<---If False it works!
    Set MyMate = AssyDoc.AddMate5(1, 0, True, 0#, 0#, 0.001, 0.001, 0.001, 0#, 0#, 0#, False, False, 0, longstatus)
    'Part.ClearSelection2 True
Public Sub SelectComponentFaceByName(CompName As String, FaceName As String)
    Dim swApp As Object
    Dim SelMgr As Object
    Dim SelData As SldWorks.SelectData
    Dim Comp As Object
    Dim Body As Object
    Dim Face As Object
    Dim CurFaceName As String
    Const swSelCOMPONENTS = 20
    Set SelMgr = AssyDoc.SelectionManager()
    Set SelData = SelMgr.CreateSelectData
    'AssyDoc.SelectByID "pino", "COMPONENT", 0, 0, 0
    Set Comp = SelMgr.GetSelectedObject3(1)
    'If (SelMgr.GetSelectedObjectType2(1) <> swSelCOMPONENTS) Then
        'swApp.SendMsgToUser "Please Select an Assembly Component."
        'Exit Sub
    'End If
    Set Body = Comp.GetBody() ' Get the Component Body
    If (Body Is Nothing) Then
        swApp.SendMsgToUser "Component Body Unavailable."
        swApp.SendMsgToUser "Make sure not lightweight or suppressed"
        Exit Sub
    'boolstatus = AssyDoc.DeSelectByID(CompName, "COMPONENT", 0, 0, 0)
    Set Face = Body.GetFirstFace
    ' Traverse thru all body faces
    Do While Not Face Is Nothing
        ' Call ModelDoc.GetEntityName.
        CurFaceName = AssyDoc.GetEntityName(Face)
        If (CurFaceName = FaceName) Then
            'Face.Select (0) ' Select the face
            boolstatus = Face.Select4(False, SelData)
            Exit Do
        Debug.Print CurFaceName
        Set Face = Face.GetNextFace
    Loop
Many thanks in advance!
Diogo Teixeira
