Not the time for the calculations to finish. Does Floefd do it until everything plateaus, like temperature etc. Or does it show what would happen after an hour or so?
Thanks in advance
Thanks in advance
When running in "steady state" mode the simulation will continue until all user goals have achieved convergence. I'm not sure exactly what happens if the user does not specify any goals. The software automatically determines convergence criteria but you can manually adjust these values.
In "transient" mode you can set your time step and simulation duration.
