JBJohn Boire09/11/2017
So here is my issue, I have a macro set up to go through sheets in a drawing and add document numbers to the sheets. (I want to make it difficult to do manually but easy to do when setting up a drawing the first time)
However when I try to edit the note I run into an issue,
I select the note as follows:
ret = swDwg.SelectByID("DetailItem1020@Sheet Format" & i + 1, "NOTE", 0.209024, 0.198179, 0)
Which works if the sheets are sequential and haven't been rearranged
However if this makes the document numbers follow the order in which the sheets were added to the drawing. So if I rearrange the sheets  from 1,2,3,4 to 1,3,4,2
The document numbers  would also get re-ordered
I tried putting a loop before the main loop that renames the note
For i = 0 To (SheetNum + (SheetNum / 2))
    If i <= SheetNum - 1 Then
        swDwg.ActivateSheet (SheetName(i))
            If ret = True Then
                Set selObj = selMgr.GetSelectedObject2(1)
                ret = selObj.SetName("DOC#")
Next i
This sets the document name to DOC# , but when I run a loop later to check if there is something called DOC# and to select it, it doesn't work.
For i = 0 To (SheetNum - 1)
               boolstatus = swModel.Extension.SelectByID2(SheetName(i), "SHEET", 0.2, 0.05, 0, False, 0, Nothing, 0)
                ret = swDwg.SelectByID("DOC#", "NOTE", 0, 0, 0)
                Debug.Print (ret)
                    'Check to make sure that an object was selected
                If ret = True Then
                'Gets the text note, which should be SldWorks.Note object
                'Call the SldWorks.Note.SetText method to change the text
                    ret = selObj.SetText("<FONT size=11PTS>" & PS(i))
                    swModel.ClearSelection2 True
               Else
               (A bunch of code that adds another 2 Notes)
I can't figure out why this doesn't work. Is there something I am missing?
Edit:
I checked it and the reason is that it still needs the format part
So new question, is there any way to renumber the format?
