Re: Why cant I copy drawings sheet to another page in
Dave Metheney Nov 9, 2017 11:58 AM (in response to Dave Metheney) -
John Stoltzfus Nov 9, 2017 12:00 PM (in response to Dave Metheney)Are you using Multiple Page drawings in one file or multiple files ??
Dave Metheney Nov 9, 2017 12:31 PM (in response to Dave Metheney)I think I got it I just had to rename the sheet number
Hardik Patel Nov 10, 2017 12:21 AM (in response to Dave Metheney) -
Deepak Gupta Nov 10, 2017 1:19 AM (in response to Dave Metheney)Dave, I had tried various combinations to copy and paste sheets in same drawing and different drawings. All methods worked so I'm bit curious as why you got that error. Could you share what process /methods you are using which got you that error?
Glenn Schroeder Nov 13, 2017 8:37 AM (in response to Deepak Gupta)I get that error message occasionally also, but for me it happens when I'm trying to copy and paste a drawing view instead of a sheet. I've never figured out what causes it.
Glenn
Deepak Gupta Nov 13, 2017 10:38 AM (in response to Glenn Schroeder)Glenn, if you happen to see it next time, please share the reason (in case you find out) OR the process/steps which caused it.
Glenn Schroeder Nov 13, 2017 10:50 AM (in response to Deepak Gupta)Deepak Gupta wrote:
I'll bookmark this Discussion and reply back when it happens, if I remember.
Stavros Smith Nov 14, 2017 9:48 AM (in response to Glenn Schroeder)Deepak Gupta Glenn Schroeder, I have encountered this as well when copying views. It appears to show up, if you try to paste without first clicking on the paper area (or paste into the white space off the sheet). It also tends to happen when you attempt to copy a detail or section view without the parent.
Dave Metheney Nov 10, 2017 8:11 AM (in response to Dave Metheney)I believe the sheet name was invalid or something to that. I renamed the sheet and it worked. Thank you for the input much appriciated
Dean C. Hall Nov 13, 2017 11:07 AM (in response to Dave Metheney)Coincidentally I had this happen to me this morning. The drawing i was copying a page from, i copied and then closed the drawing out. I got the same error message. I opened the drawing I was copying from again, recopied and left the drawing OPEN, went to the new drawing and pasted it perfectly fine. The drawing that you are copying from must stay open (just minimize it) when pasting to a new drawing packet.
Dave Metheney Nov 14, 2017 8:12 AM (in response to Dean C. Hall)I could copy it and paste it without it being open. The sheet I was trying to paste had a sheet number like sheet1of2. I renamed it just sheet 1 and it worked fine.
