Save As PDF in Different Folder Using Macro
Question asked by Salman Faiz on Nov 10, 2017
Latest reply on Dec 14, 2017 by Solid Works
I have a following code which is not allowing me to save file to PDF. I was wondering if someone can help me with it.
This code, checks if a folder exists and if not it creates the folder, add revision number to the file name. I will appreciate if someone can help me in getting the save as pdf part correct.
Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.ModelDoc
Dim Filepath        As String
Dim FileName        As String
Dim PDFFileName     As String
Dim InterPath       As String
Dim PDFPath         As String
Dim oFolder         As String
Dim Revision        As String
Dim boolstatus      As Boolean
Dim PDFPathandName  As String
'Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swDraw = swApp.ActiveDoc
'Check to see if a drawing is loaded.
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
'If no model currently loaded, then exit
Exit Sub
Filepath = swDraw.GetPathName
InterPath = Left(Filepath, Len(Filepath) - 31)
MsgBox (InterPath)
PDFPath = InterPath & "01 Released Drawings" & "\PDFs"
MsgBox (PDFPath)
Revision = swDraw.CustomInfo("Revision")
FileName = swDraw.GetPathName
PDFFileName = Left(FileName, Len(FileName) - 7) & "-R" & Revision & ".pdf"
MsgBox (PDFFileName)
oFolder = PDFPath
If Dir(oFolder, vbDirectory) = vbNullString Then
MkDir (oFolder)
MsgBox "Folder Created"
PDFPathandName = PDFPath & "/" & PDFFileName
swDraw.SaveAs (PDFPathandName & ".PDF")
