Importing .asc file using circuitworks and the board thickness is not correct. any idea of how to fix board thickness?
Check the thickness value in your pcb design software. Our guys who used Cadence didn't ever set the Z value and when I tried importing a PCB assy once all the components were Z= 500mm
Steve C
Thanks Steve!
Also, I just discovered that even though the 'Thickness' property of the "Board Extrusion" feature is read only, the thickness values of each Layer are adjustable. It's not ideal, but at least I can correct the board thickness. In my case, I don't have much influence over the files I get to import.
Me too. The default pcb thickness is 3.349mm [0.132 in], which isn't correct. I'm not sure if the problem is my CircuitWorks setup, or that the PCB guy has an incorrect property in the *.ASC file that I'm importing. I'd love to know if there's a place that I can override this default thickness. Changing it manually after the fact is a pain.
