I downloaded a step file. I got this error. is this step file corrupted? After hitting OK button, nothing displayed.
Hi Paul,
Thank you. Have you read that xxx.err file? I could not find that file. I wonder what it is.
Chika,.. I get the .err file,.. and after further review, the stp on their site is truncated.. that is,if you open up the stp in a text editor, it stops at entity #2160... so, if I open the other step file as a txt file (btw, the other step Dennis suggested reads without any issue, I'll attach the assembly here) it looks to be the same file... and if I copy/paste remaining lines from #2106 to the end of the file (image attached)... it imports without any problems.... so, the stp file (from SW 2009) on their site is truncated.
I also get the same error. I accidentally downloaded the a8064chnfss (without the 6) file and it opened fine. It looks as though, from the data sheets, that the only difference is one is 304 sst and the other is 316L.
