This content has been marked as final.
Show 2 replies
Re: Static Analysis of structure
Andrew Cuttle Nov 8, 2017 6:57 AM (in response to Ankit Patidar)Unless you're running the analysis on a very flexible assembly, the large displacement warnings are usually a sign in the FEA that the bodies aren't fully constrained.
Do you have an image of your analysis and the applied constraints?
Felipe Marchant Nov 16, 2017 7:38 AM (in response to Ankit Patidar)Maybe you can probe use the spring option to give stability to the model. You can select this option in the properties of the analysis. That give you an idea, of which part not has the sufficient constraint.
