Re: My text cursor is missing when I edit note text - how can I get it back?
Glenn Schroeder Nov 6, 2017 11:20 AM (in response to Diana Anzaldua)I don't remember anyone else reporting that, and I'm pretty sure there isn't any way to manually turn it off or on. Have you tried using the right or left arrow keys on your keyboard to see if that will make it show up, or at least give an indication of where it should be?
Diana Anzaldua Nov 6, 2017 11:36 AM (in response to Glenn Schroeder)Arrows keys don't help.
Kelvin Lamport Nov 6, 2017 11:33 AM (in response to Diana Anzaldua)OK, here are the usual initial support questions;
Have you tried restarting SW, or rebooted the system?
Have you recently updated Windows or SW?
What OS, SW version, graphics card & driver are you using?
Diana Anzaldua Nov 6, 2017 11:49 AM (in response to Kelvin Lamport)Kevin,
1. Yes, I have rebooted several times since the issue started.
2. Yes, I recently updated Windows.
3. I am using Windows 10
4. SW 2017 SP 3.0
5. NVIDIA M1000M Driver Version 22.21.13.8477
Thanks for your help.
Glenn Schroeder Nov 6, 2017 11:46 AM (in response to Diana Anzaldua)I said I didn't remember anyone else with the same issue, but I have a notoriously bad memory. Kelvin Lamport found this, which reports the same, although no one replied with a fix.
Kelvin Lamport Nov 6, 2017 11:51 AM (in response to Glenn Schroeder)Glenn Schroeder There are several hits in the Knowledge Base about text note cursors, but nothing about them being missing.
Dan Pihlaja Nov 6, 2017 11:52 AM (in response to Diana Anzaldua)Are you having issues similar to this?
Diana Anzaldua Nov 6, 2017 12:14 PM (in response to Dan Pihlaja)In my case, it's just not there at all. It's only missing in Solidworks notes. It's there when I edit a dimension. It's fine in all other programs (excel, word, email, etc.).
Diana Anzaldua Nov 6, 2017 12:16 PM (in response to Kelvin Lamport)Hmmm. Well, maybe one of these days it will reappear. I can work around it but it's annoying.
Diana Anzaldua Nov 6, 2017 1:20 PM (in response to Kelvin Lamport)Thanks, I will.
Justin Byerly Feb 13, 2018 10:32 AM (in response to Kelvin Lamport)I am having the same issue on 2018. I put in my vote. Thanks for the info.
John Lunsford Feb 13, 2018 6:37 PM (in response to Justin Byerly)I'm having the same issue, in both 2017 & 2018. The cursor is present and accounted for in 2015 on the same machine.
Anyone have some new suggestions?
Matthew Siok Mar 16, 2018 9:00 AM (in response to John Lunsford)I am getting the same issues in Solidworks 2016 SP4 (yeah we're behind a little), I'm installing SP5 to see if that fixes but from what i'm reading here I'm not too hopeful.
I just switched and got a new laptop from a tower but in terms of updates to OS i'm running on essentially what i was before.
Kyle Mitchell Jul 9, 2018 10:36 AM (in response to Matthew Siok)Same issue. 2018 SP3, recently upgraded from Windows 7 to Windows 10.
I have up to date graphics driver for both, never experienced this on Windows 7 but now happening on Windows 10.
Jason Blondin Jul 17, 2018 9:21 AM (in response to Diana Anzaldua)Same issue for me. 2018 SP3 win10
Reynold Christian Aug 6, 2018 7:30 PM (in response to Jason Blondin)OKAY SO I ALSO HAD THE SAME PROBLEM WITH THE CURSOR NOT APPEARING AT ALL WHILE EDITING NOTES IN DRAWINGS,I AM RUNNING SOLIDWORKS 2018 SP 0.1 AND I SOMEHOW MANAGED TO FIX IT.
1.CLOSE ANY DRAWINGS OR ANY FILES YOU MIGHT BE WORKING ON
2.GO IN TOOLS/OPTIONS/SYSTEM OPTIONS/PERFORMANCE
THEN CHECK : " USE SOFTWARE OPENGL"
I HOPE IT HELPS!!
Justin Byerly Aug 6, 2018 7:37 PM (in response to Reynold Christian)AWESOME! It worked for me! I am not sure what else changes with that box checked but I can stop losing my hair. THANK YOU!
Kelvin Lamport Aug 6, 2018 7:59 PM (in response to Justin Byerly)Reynold Christian and Justin Byerly
If using that option fixed your problem, then you either have a non-approved graphics card or are using an incorrect graphics driver.
David Brukardt Aug 6, 2018 9:45 PM (in response to Kelvin Lamport)Kelvin,
Where I work just upgraded to SW2018 SP3.0 on about 100 computers. Some are on Win 7 others on Win 10. Some on towers and others on laptops. All have approved graphic cards and drivers. Out of those there is one user on a laptop running Win 10 that does not get a text cursor unless running OpenGL (there are several other computers with the same configuration that do not have the issue). When we figure it out, I will report back.
Kyle Mitchell Aug 7, 2018 3:10 AM (in response to David Brukardt)I had the same issue SW2018 SP3.0, recently upgraded to windows 10 and installed the approved graphics driver.
I've just tried this option and yes the cursor did come back in drawings, however overall performance was severely affected. Is this pointing towards a problem with the approved driver for Windows 10? Mine is also laptop.
Thanks, Kyle
David Brukardt Aug 23, 2018 11:39 PM (in response to Kyle Mitchell)Yes running OpenGL will downgrade overall performance (bypasses the graphics card). Besides running OpenGL, I have found two other solutions.
1) Set SolidWorks to use the integrated graphics built into the motherboard.
2) Go into the NVIDIA Control Panel (if you have an NVidia card) and in the Manage 3D Settings section Global Settings tab set the Base Profile to use the Integrated graphics and in the Program Settings tab set SolidWorks to use the graphics card. The only issue I have with this is I do not know how this will affect the performance of other applications. I have tried to get SolidWorks opinion on this but so far they have not gotten back to my VAR. This "fix" may not work on all computers; our laptops are Dell 7720 with a NVidia P3000 graphics card.
Kelvin Lamport Aug 7, 2018 8:03 AM (in response to David Brukardt)David Brukardt and Kyle Mitchell
What is the make & model of the problem laptop, and what graphics card and driver is being used?
Kyle Mitchell Aug 7, 2018 8:31 AM (in response to Kelvin Lamport)Hi Kelvin,
Dell Precision 7510, NVIDIA Quadro M2000M, driver 386.07 on Windows 10.
*edit* this never happened before upgrading from Windows 7.
Thanks, Kyle
Todd Blacksher Aug 7, 2018 9:20 AM (in response to Kyle Mitchell)Kyle Mitchell wrote:
Thanks Todd!
I'm just glad to see that you are NOT on one of the "extra-buggy" versions!
Todd Blacksher Aug 7, 2018 11:26 AM (in response to Justin Byerly)Justin - This is extremely rare, but there have been issues with the latest driver from the card manufacturer vs. the latest "approved" driver from SOLIDWORKS.
Like I said, it is super rare, so it probably isn't an issue, but just so you know . . .
Justin Byerly Aug 7, 2018 11:31 AM (in response to Todd Blacksher)Thanks for the info. I will keep that in mind.
David Brukardt Aug 23, 2018 11:42 PM (in response to Kelvin Lamport)Kelvin,
I mention my computer and graphics card in my last post. Driver is 386.07 which seems to be the only approved driver for SolidWorks 2018. We have at least 4 different graphics cards (due to the type and vintage of our computers) and SolidWorks recommends the same one for all of them.
Diana Anzaldua Aug 7, 2018 6:59 PM (in response to Reynold Christian)Thank you so much. That worked for me.
Diana
Henk Bruijn De Aug 8, 2018 3:08 AM (in response to Reynold Christian)I had the same problem with my laptop Dell Precision 7520 with WIN10pro and SW2018 SP3 with certified hardware and downloaded Solidworks recommended driver for the Quadro card.
The "USE SOFTWARE OPENGL"-trick worked for me too.
Thanks Reynold Christian .
Douglas Stone Oct 3, 2018 10:33 PM (in response to Reynold Christian)The "Use Software OpenGL" is for debugging. It removes the hardware from the loop and just checks that SolidWorks is running as it should. When your issue is "fixed" when this is activated it really means that your graphic card and/or driver are not working as intended. Basically your issue, not SolidWorks problem. Update your driver etc. and it might fix it, it hasn't in my case.
With the "Use Software OpenGL" active your graphics card is not being used so you are wasting money on it for not benefit. You've paid the big bucks for the fancy CAD card I would want it to do its job.
John Matrishon Aug 7, 2018 12:23 PM (in response to Diana Anzaldua)In addition to the driver issue (most likely), keep an eye on Windows 10 display scaling. It tends to default to 125% with some themes, and depending on your driver and screen resolution settings that can cause some interesting things. Recommend using 100%.
Lets also not forget that some Win10 setups will automagically update your graphics card drivers for you.
JM
Dave Nall Feb 7, 2019 11:10 AM (in response to Diana Anzaldua)OK, so the OpenGL worked for me, I finally have a cursor back, but now something has changed and it is really slowing/crashing my system.
SW now traces every geometry line when I mouse over something in the FeatureTree. What is this feature so I can turn it off.
Thanks.
