I would like to control dimensions, configurations and state of components of an assembly by means of an excel macro. I am starting slowly with a basic assembly with only 2 components (square and triangle). So far, I managed to control the dimensions and configurations of the components. However, I am stuck on the state changes. It seems that no mater what command I use, it ONLY suppresses the components. I can never resolve the components... Anybody can help me with this? I am quite new to excel vba macro programming for SW...
Here is my code:
Sub Button1_Click()
Dim Part As Object
Set Part = swApp.ActiveDoc
'--- Changing dimensions of components in assembly ---
Part.Parameter("Side@Sketch1@Square.Part").Value = Range("C5").Value
Part.Parameter("Height@Boss-Extrude1@Square.Part").Value = Range("C6").Value
Part.Parameter("Side@Sketch1@Triangle.Part").Value = Range("F5").Value
Part.Parameter("Height@Boss-Extrude1@Triangle.Part").Value = Range("F6").Value
'--- Changing mate dimensions in assembly ---
retval = Part.Parameter("Square@Distance1@Assembly.Part").SetValue2(Sheet1.Range("I5").Value, 1)
retval = Part.Parameter("Triangle@Distance2@Assembly.Part").SetValue2(Sheet1.Range("I6").Value, 1)
'--- Changing configuration of components in assembly ---
Set swComp = Part.GetComponentByName("Square-1")
swComp.ReferencedConfiguration = "Big"
'--- Changing state of components in assembly ---
'swComp.SetSuppression2 (swComponentSuppressed)
swComp.SetSuppression2 (swComponentResolved)
Part.EditRebuild
