DBDonald Bolden03/11/2017
I want to add a default surface finish to my tolerance block on my drawing format's but unless it is done in the Edit Format Sheet layer, it won't be saved. Surface finish is not an option during Edit Format. I was going to make a block so I can add it to the Edit Sheet Format but surface finish is not an option anywhere that I can input it. How do I work around this.
